http://www.uga.edu/nchfp/how/can_02/..._fillings.html
General: Each canned quart makes one 8-inch to 9-inch pie. The filling may be used as toppings on dessert or pastries. Clear JelŽ is a chemically modified corn starch that produces excellent sauce consistency even after fillings are canned and baked. Other available starches break down when used in these pie fillings, causing a runny sauce consistency. Clear JelŽ is increasingly available among canning and freezing supplies in some stores. If you cannot find it, ask your county Extension home economist about its availability in your region. Because the variety of fruit may alter the flavor of the fruit pie, it is suggested that you first make a single quart, make a pie with it, and serve. Then adjust the sugar and spices in the recipe to suit your personal preferences. The amount of lemon juice should not be altered, as it aids in controlling the safety and storage stability of the fillings.
When using frozen cherries and blueberries, select unsweetened fruit. If sugar has been added, rinse it off while fruit is frozen. Thaw fruit, then collect, measure, and use juice from fruit to partially replace the water specified in the recipe. Clear JelŽ is available only through a few supply outlets and is not currently available in grocery stores. Find out about its availabilty prior to gathering other ingredients to make these pie fillings. If you cannot find it, ask your county extention home economist about sources for Clear JelŽ.
