Water Blan B
http://www.preparednesspro.com/blog/water-plan-b/
Water Plan B
by Kellene Bishop
Water storage--do you have enough?
As you know, I’ve strongly recommended in the past that you store at least one gallon of water per person, per day in order to be prepared for unforeseen events. However, what if you don’t have the luxury of benefitting from that which you have stored in your home? Well, here are a few “plan B” options for you.
1) Dry Creek Bed: If you see a dry creek bed, you’re most likely in luck. Follow the creek bed down-slope until you come to a bend in which the flow “s-curves” to the outside. Dig a hole about 2 feet away from that external part of the s-curve. You should only need to dig about a foot down. Voila. There should be water there, and you should be able to drink it due to the soil cleaning it. When in doubt though, always filter your water prior to drinking it.
2) Standing Water Pond: Chances are if you see a standing water pond that water is NOT safe to drink. It very likely has animal feces, a little dash of West Nile Virus, and a sprinkling of other lovely bacteria. So, dig a hole about 2 feet down, two to three feet outside of the standing water spot. That water will also be filtered from the soil. Grant it, it will be dirty, but it won’t have the feces and other bacteria.
3) Leafy Tree Limbs: If you’ve got leafy trees, you’ve got filtered water. Simply take a piece of plastic and secure it tightly around the leafy tree limbs. You can use rope, or rubber tie downs. Allow the plastic wrap to rest around the limb during the sunny part of the day. This will create a solar still for you, thus extracting the water from the leaves. You can then carefully take the bag off of the limbs, and consume the collected water.
4) Moisture in the Air- Yup. It can be yours if you simply capture it. This bodes true even if you’re out in the middle of the desert. Dig a 6-19 inch deep hole in the ground. Place an open container (i.e. bucket, can, pan, etc) in the middle of the hole. This will be collecting your water. Place a plastic sheet securely over the top of your hole. Secure and “seal” the outside perimeter of the sheeting with heavy rocks and even some dirt and sand. Place a rock in the center of your plastic sheeting directly about your collection container. This will concave the sheeting a bit so that as water condensation occurs, it will naturally drip into your container. After about 12 hours, you will have drinking water.
While this last strategy may not be a water source help to you, it may be useful if you have access to water but no fuel with which to clean it. Simply fill a clear 2 liter pop bottle with strained water (to get rid of the big stuff.) You can simply run the water through a cloth or a sieve, etc. You just want to get the big pieces out of it such as sand, silt, leaves, etc. Set your pop bottle out in the sun for 6 hours. The UV in the sun will kill all of the virus’ and bacteria after 6 hours.
Once again, I hope this information puts you more in the driver’s seat of any curve balls life may throw at you.
The Following 3 Users Say Thank You to Sgt Prepper For This Useful Post:
AZ Prepper (01-31-2010), Carinslp (07-08-2010), DMGNUT (03-13-2010)
