How To Get Water From Your Well In A Grid Down Situation
I have been looking for an economical way to get water from my well in the event of a prolonged power outage. I would love to have the money to install a 240v solar panel system, or buy a nice big genny with lots of fuel but that is just not in the cards right now.
I have looked at the deep well hand pumps like the Bison, but even they are out of my reach at $400+.
Today I was listening to a great podcast by Cope Reynolds. (http://www.theshootingbench.net/) and he was interviewing James Rawles. Mr. Rawles mentioned a torpedo bucket is available from Lehman's that is made to fit down a 5 to 8 inch well casing. Well I looked them up and they really seem to be a great economical solution to access well water when the power is not on.
Besides being affordable, I can see this being alot easier to help neighbors. Once I have my water drawn for the day, they could borrow my bucket and draw their water. A lot easier than lugging a genny or PV panels over to them.
Here is the link at Lehmans:
http://www.lehmans.com/store/Water__...___550202?Args=
Galvanized Well Bucket
Previous Product | Next Product
Get water from any well by hand
Works at any depth
Special leak-proof valve opens to fill then closes automatically when bucket is drawn up
Use for emergencies or temporary installations
Not intended for everyday use
Galvanized steel with watertight, soldered seams
Reinforced with 16-gauge crossbar and extra-strong bottom
You may have to remove any installed submersible pump before using a well bucket
Holds 1.9 gallons
Fits wells down to 4"ID
2" welded ring for rope
3½"ODx52"L
4 lb.
Locally made by the Amish.
Note: Although we pack our products carefully, this item is difficult to ship without acquiring some small dents. The performance of the bucket will not be affected.
Check out our Water Information Center which includes helpful articles about
Common Water Contaminants
Water Tests
Cross Reference Chart for Water Filters
Pumping Basics for Deep Wells
Pumping Basics for Shallow Wells
There was also a post at www.survivalblog.com about how to make your own torpedo bucket out of PVC:
http://www.survivalblog.com/2007/06/...o_or_bull.html
Letter Re: Well "Torpedo" or "Bullet" Bucket Construction Plans
Jim -
Do you have a diagram or plans for a well torpedo? In case I have the term wrong, a PVC tube with a flapper valve at the bottom that when sent down the well shaft hits the water, the tube fills/sinks, when you pull on the rope the flapper valve closes sealing in the water for you to pull up the well shaft. I have the well. What I need is the way to install the flapper valve. Thanks, - DAB
JWR Replies: For any readers that aren't familiar with them, narrow shaft well buckets--also sometimes called "bullet buckets" or "torpedo buckets" are designed for manually drawing water from modern modern small diameter wells that are more than 20 feet deep. Shallow wells (less than 20 foot depth) are much more efficiently accessed with a hand pump, such as a traditional pitcher-type cistern pump (available from Lehmans.com) or this home-fabricated PVC design by Keith Hendricks, shown at the PermaPak web site. Deeper wells require a sucker-rod actuated pump.
Have a deep well but you can't afford a manual pump or you don't foresee anything but short term emergency need to draw water? A bucket will do. The following method works, but you will first have to pull the pump, wiring and its draw pipe before you can use an emergency bucket. Most modern wells have 4-inch or 6-inch diameter casings. Well buckets can be made from PVC pipe and some fittings available at nearly any hardware store. (The only hard-to-find item is the foot valve.) Use a 4 or 5 ft. length of 3-inch diameter white PVC pipe if your well has a 4" casing, or 4" diameter pipe if your well has a 6" casing.
Assembling the Bucket:
For the top cap, drill a hole in the center and insert a threaded eye-bolt with lock washer and nut to hold the lifting/lowering rope. Use PVC cement to attach the pipe cap. Be sure to use sturdy nylon rope. (Recovering a bucket if the rope breaks would be problematic, to say the least.) In the bottom cap, drill a centered hole and install a "foot" valve. This will be open when floating and allow water in to the bucket. The valve will automatically close when the bucket is pulled up. Foot valves (also called "check valves") are available in PVC construction, as well as brass and cast iron. Depending on the type of valve you buy, you will probably have to screw a threaded pipe adapter (male-to-male short coupling) to into the top of the valve and then glue it into the appropriate size hole that you have drilled into the end cap. Needless to say, you need to be sure that the valve's "flapper" is oriented in the right direction before you attach it to the bottom cap. You need the bucket valve to hold rather that release water when the bucket is raised!
OBTW, for anyone that would rather buy a commercially-made well bucket, they are available from Ready Made Resources (search on "Well Bucket"), and from Lehmans.com (search on "Galvanized well bucket".)
The Following 2 Users Say Thank You to Sgt Prepper For This Useful Post:
Kelly Alwood (02-17-2010), Knightstar (02-18-2010)
Re: How To Get Water From Your Well In A Grid Down Situation
That looks like a great option for water. Ill check it out.
Thanks for the research.
